b18b1 synthetic oil good??
  • b18b1 synthetic oil good??
    is synthetic oil good to run on a built b18b1 block?? and what kind of oil should i use??
    use regular oil!!!!!!!!!!! start it up on straight 30 then 10w30
      from my personal experience it blows away any oil period thats out there today...if this vid dont prove it idk wut willl lol,,
        Originally posted by lsvtecrex View Post
        http://www.youtube.com/watch?v=kqvhri7-ima
        just bought some lastnight
        WILSON BUILT
          my cars used mobile 1 for all 90k.. is it safe to switch to royal purple now? i heard somewhere never to mix ..
            so could i use one quart of straight sae 30 and than add 3 10w30's???
              its ok to switch over as long as you do not got back to reguler oil
                eneos ftw!!!
                  yeh even if u only use one quart of royal purple and 3 quarts of mobile 1 synthetic ur engine will benefit from the purple,,its that good,,,use just royal purple although quite pricey then ur engine will take more abuse longer
                    walmart 8.47qt
                    WILSON BUILT
                      if the motor is fresh you have to break it in with regular oil. oil weight depends on your bearings clearance. if you bearings are tight, you can run on piss water... if you bearings are loose, you need thicker weight. for example if you run a motor on 5w and your rod bearings are clearance to .023(way loose out of spec), there is a chance for the crank to break through the oil film and have bearing to crank contact = spun bearing.
