help electrical issue
  • help electrical issue
    hey crew i need help. took my car out lastnite to get sinus meds, cam home no problems. wake up got to start it around 1 to go to familys for football, turn it over and click click click. so get a battery charger and pop it on, car starts right up, let in run about ten min turn it off, try to start it right back up click click click. so i pop charger back on and i take my car and bring charger with me, and gf follows. all the accessories work and stuff. although my SRS light pops on randomly just started, wondering if it has anything to do with it. besides it being just replacing the battery, is there any other possibilites here. also wen i got home the car was kinda idle surging wen it was parked, but never died out just a steady room room room, which it wasnt doing earlier. any help is appreciated thanks guys and gals
    2000 EBP EM1
    sounds like a dead battery. prolly shit the bed from the cold weather obviously not the alternator cuz it runs fine after jumped. As for the SRS light I would guess maybe it reset the battery when you used the jumper pack? im not too sure. if not could be your srs computer?
      may be ur alturnator thats y it idles funny wont turn off but lights start to coome on cuz there turning off
      B SERIES INC....
        only thing pushin me from alternator is i had a similar problem with my ek hatch, and it was alternator and everything would dim down and eventually car died out completely
        2000 EBP EM1
          no not the alternator if it runs fine after being jumped. but pull the positive terminal off after it's running and see if it stays running or not.
            just sayin cuz my hatch had a bad alt and it idiled like crazy but i drove it from milford to new haven without it turn off
            B SERIES INC....
              it ran fine both times earlier, the idle thing happened wen i just got home, but it was steady, didnt die out at all, and no power loss on drive home at all
              2000 EBP EM1
                Did you replace the battery? When I had a bad battery that wouldn't hold it's charge when i connected my positive terminal it idle shitty. When I took the terminal off and ran just on alternator it idle'd better. Id replace the battery n go from there.
                  sounds like a junk batt
                    yea mines was the same but just try wat ls vtec said if it turns off its ur alt if not than its ur battery
                    B SERIES INC....
                      def battery.
                        frank, you gotta a battery laying around :D
                        2000 EBP EM1
                          u dont do that period,if the alternator spikes the battery is there to absorb the extra voltage. if u disconnect the battery while running u run the risk of frying shit. use a volt meter when checking for alternator voltage
                            yea i wasnt pullin nuttin off, pizza boy i was jus gunna hit u up on facebook and see if u had any ideas here
                            2000 EBP EM1
                              lol for the sputter n srs i would say check all grounds n then slap a battery in
