car finally started
  • car finally started
    after 2 months without my car its running my first swap done put i guess one of my break lines broke so i have no brakes and wen im driving wen i get to like 4000 rpms it jerks wat could tht be
    ecu or dizzy.
      x2
      My transmission's went 9's
      http://youtu.be/z2PHemIp_Tg
        also known of the vaccum lines are on only map right now can tht be a issue to
          had same exact problem , when u hit 3 to 4k rpm u got switch gears if not the car will feels like it want to stall (rite). Its either ur useing the wrong distribution that has diff specs, ur distributor timing could be off check it with a timing light. or make u got good connection with ur distributor internal like that little ignition spring, and rotor to make sure it not burned, the distributor cap, also check ur spark plug gaps.GOOD LUCK
            If you have open vacuum lines, that means you have a vacuum leak.. the engine will never run right if theres un-metered air entering the intake manifold. Hook everything up to the correct places.
              yeah thanks alot thats what exactly is happening ima drop it off at a mechanic today to get everything straightened up i will let use no
