Thermostat
  • Thermostat
    My car is running fine. The gauges work. It doesn't want to warm up after 15 minutes in the cold, the temperature would slightly rise after a certain period driving then go back down. I do have a racing radiator and I don't know if it really makes the car run a very cool temp. I know running too cold or hot is not good, just the right temp.
    Can it be the thermostat? Just want to get some thoughts. Thanks.
    do you get good heat from the blower?
    one way to tell if the thermo is working is feel the lower hose after 15mins if its hot it works if not you know what you gotta do!
    NHSWAPS13203 > *
      well said chop. i'll check it out.
        okay problem solved. the temp is just right and the heat from the blower is warmer. if you guys have the same issue like i had, here ya go.
        got me a $15 stant thermostat, good enough for my dd.
