I have a ef with a d16y3 in it and the vtec isnt wired in. How do I do this and what do I need to make the vtec work?
91 EF with D16Y3 OBD 1 motor vtec help?
you will need a OBD coversion harness for the ecu and you run a P28 ecu and then you will have to run the vtec wire fromt he ecu to the vtec soniolind and presser senser and you will need a jumper harness for the dizzy to put a obd1 vtec one on thereRIP Nick
