- does any one have any idea what could be happening,,
- i have a 4dr ef single cam 1.5 non vtech,,
- my problem is piston number 3 is not responding,, when you look at the motor it shakes,, nd when u give it gas it sounds like a valve is bent,, i replaced fuel injectors, spark plug wires, spark plugs, cap & rotor, and nuthing i did a compression test nd the piston has 151 lb.
- i took th head of sent it to the machine shop nd they told me no valve are bent nd the head is in good condition,,
- now i put in a new head gasket put everything on and everything seems to be the same with the same problems,,,
-ANY CLUESS ???????
-ANY CLUESS ???????
