i just got a free d15b7 motor i got y8 build head how bad would it be on 5psi? any 1 done this before for boost?
minime
bump... single cam Power FTWLast edited by coupejordan27; 10-18-2011, 08:23 PM.EM1-860-CTmember..1...
J-SWAPS ....860-457-8335
been done a bunch of times it will work with the right tune and you will need a adjustable cam gear and make sure you pull out the oil jet from the block befor you put the head on. and invest in some arp head studs and a MLS head gasket! good luckRIP Nick
Originally posted by jdmtim27 View Postjust did the minime in my coupe with the z6 head on a b7 block. if your gonna leave it stock and boost it make sure you keep the boost level to a minimum
no more 5psi!!!!!lsvtec nitros hatch---build ls turbo hatch---sohc nitros hatch---gmc sierra---
