throwoutbearing or input shaft?
  • throwoutbearing or input shaft?
    how do i tell the difference between the two when they go bad...?
      if when you push your cluth in the noise stops its your throwoutbearing
        Google is your friend
        Honda Civic / Del Sol (1992 - 2000) - Throw out bearing or input shaft bearing? - 96 civic ex When I am driving my car makes a light whining/grinding noise sometimes. If I push the clutch in it goes away, and it doesn't make the sound if in neutral. Sometimes it won't do it at all and sometimes it does it all the...
        Should answer your question, I hope!
          ive heard opposite smh...shits annoying
            If the thra bearing make noise push in the cluch peddle if the noise go away the thraw bearing mest up
              i was actually reading that earlier...
                It's really not confusing once you look at the tranny when you detach the motor from it. When you hit the clutch, the "clutch slave cylinder" pushes on a clutch fork.....It's a simple two prong thing thats clipped onto your throw out bearing. The bearing rides on the shaft. So, if you're hearing a noise except when you clutch in, the bearing is bad. If it was consistent, it's the shaft by deduction.
                  it goes away when i press in the clutch. but when the clutch is out it sounds like glass in my tranny lol and its been getting worse...
                    Throw out bearing.
                      deff throw out bearing
                        then it is you input shaft bering!
                        the tranny is spinning with the clutch out not in gear so the input bering is spinning ( noise you here)
                        when you push the clutch in the noise will go away (tranny not spinning) if the noise is gone with clutch in the your input shaft bering is bad.
                        is it a B or d series transmission?
                          d series
                            then most DEF the input shaft bering they are very common to have input shaft bering issues. hit up MRniceguy he can fix ya up quick
                              ive pmed him before to swap a casing for me he hasnt written back...soooo
