h22 integras?
  • h22 integras?
    hey guys just had a question. i wanted to see what u guys with h22 integras have for cv shafts. thanks
    i went to google and look what i found
    H22 Into an Integra A conversion from B18C1, to H23A1, to JDM H22A VTEC PARTS REQUIRED H Series Motor A Mount kit (www.hasport.com) (www.placeracing.com) Custom axles Custom Radiator Custom Radiator Fan Custom Welding of Catalyst 90-97 Accord Shift Linkage, all lines running up to cabin 97-00...
      yea i had seen that already but i wanted to see if anyone here had an integra with a h22 to see what they had. reason being is cus im having trouble with mine.
        i know someone who had it done, they took a b series shaft and mated it to the h22 input shaft on the tranny.. its simple
          b series axles should work but i would buy aftermarket one better
          Follow me @bolacan413
          Follow the build @k_insight
            it is my boy is a pro at it lol we changed em mad times
            INTEGRANATION MEMBER #10
              h2b....
                i have after market ones but it seems like the driver side one is too short. it has a lot of play.
                  h22 teg uses the same axles as h22 civic...
                  im using the accord intermediate shaft with a 90-93 integra axle on the left side and a 86-89 integra axle with accord inner joint (so the snap ring works.)
                    stop being cheap dont cheap out in axles nor mounts buy name brand.. innovative ones work perfect neer broke an axle in my h22 civic
                    203 Crew Memeber # 57
                      http://hondaswap.com/swap-articles/h...integra-29122/
                      thats a sick right up i was goin to build a h22 this summer and put it in my hatch and that helped me alittle more to do the swap thanks
