please hook me up with brake help
  • please hook me up with brake help
    i snapped a wheel stud today..so i took off caliper and now i cant get my rotor off..any suggestions??
    Put a screw thru the little hole or bang the backside with a hammer evenly
      Did you remove the two screws in the rotor ? If u didn't that thing ain't com in off now if u strip them trying to take them out then drill them out
      860 member #18
      puerto roc #1
      Cosa nostra
      ASAPRadio.net
        before you strip said screws go buy an impact screw driver.
          ^x2 that thing works wonders I bought one specifically for those screws
            I took an impact driver to the screws and got them out no problem..but the rotor is just stuck..should i just keep bangin the back of it? or is there some other way?
              bang it till it brakes lol thats the only way it will come off of try to sqeeze in some pb blaster that should work
                aight cool..thanks alot for the help people..i just wasn't sure if i was missing somthing, ill just bang away lol
                  lol how are the rotors stuck? they should slide right out after the 2 screws are off...
                    just lightly bang around the rotor with a rubber mallet
                      yes lightly bang away dont go and break your damn rotor (which you are probably doing right now) lol well good luck
                        Bfh is your friend
                        NHSWAPS13203 > *
                          Originally posted by the jdmchop View Post
                          bfh is your friend
                          bfh ftw!!!
