I have the driver side working and ready to go. The passenger side is wired up but still won't go up or down
manual to power window conversion ek
Originally posted by Jovanni91Da View PostDriver side was easy passenger just a little headache wires are connected up might have one wrong Idk
Check this thread out. It will tell you what colors go to what
Last edited by jdmdikk; 08-05-2012, 03:29 PM.Originally posted by knuckk@jdmdikk only dude i would take advice from.
Originally posted by jdmdikk View PostShoot me a pm if u need help bro. It's easy to wire them up. All u have to do is run 3 wires from the passenger door towards the drivers kick panel. 2 wires are going to connect to the 2 wires from the drivers side(same colors).the 3rd wire will be the power wire. U connect that wire to the power wire from the drivers side and put a 15 or 20A (don't remember which one) in line and connect it to your ignition wire. The 4th wire from your drivers side will be ground. They will work like factory and u can control both windows from the drivers side
http://www.hondahookup.com/forums/sh...96-00-civic-DX
did u try plugging the passenger motor into the other plug thats on the passenger harness? i had made the same mistake and all i had to do was unplug it and plug it into the other plug and it worked perfectly fine.there are 2 clips that are exactly the same.u might have it plugged into the wrong one broLast edited by jdmdikk; 08-05-2012, 07:47 PM.Originally posted by knuckk@jdmdikk only dude i would take advice from.
