Want to know what's the max boost stock sleeves can hold on a d16z6
max boost on stock sleeve d16z6?
Only D series stuff I have done was run a Greddy kit on a mini me at 12 psi. Motor just had Honda MLS HG and ARP's. Took it for a bit, but the headgasket and intake manifold gasket let go. Can still drive it around, but if you push it a little too much, my heat cuts out lol. So it's letting air into the cooling system. Going to do a rebuild on it when I finish one of my other projects.4G63T Mirage.
Blk 99' Q45t.
And more.
time and time again people try and give boost psi limits when that dont mean shit.
10psi on a gt42r and 10psi on a td04 is a big power difference so you need a hp limit not psi limit. 400hp is the max limit on stock sleeves so id say your safe at around 350, so you have some reliability out of it and not pushing its limits.
Originally posted by honda 97 View Posttime and time again people try and give boost psi limits when that dont mean shit.
But it really all depense ont he builder, parts, turbo, tuner and luck. lolMoney ain't a thing! Crew Member #1
