Neptune Rtp With Demon Board!!
Comes with Neptune program Burned To Disc
Seriel Number!
And Usb Cord!
Price Is Set At $350.00
Only Trades Will be ek Parts Such as exterior parts or nice interior parts maybe wheels
things i need
asr subframe
control arms
si wing
aftermarket grill 96-98
or 00 front end
nice seats (rsx,newer si,s2000)
carbon hood 96-98
carbon trunk ek
and will take offers
Beautiful 3D Beveled interface.
User Friendly Toolbars with the options you need most.
Real-Time Datalogging Of Sensor Data, Inputs, Outputs, and ECU Data.
On Board Logging With Lossless Compression To Allow 3 To 5 Times The Regular Amount Of Data To Be Recorded. Offers Up To 3 Hours Of Datalogging Time With Compression Enabled.
Datalog Playback, Save, and Export to CSV.
Datalog Trimming.
Datalog Commenting For Later Review or Sharing With A Tuner.
Graphing Of Sensor Information With Real-Time Values and Live Scrub (Dragging with mouse).
Live Graphing Of Real-Time Sensor Trends.
Direct Serial Logging From LC-1, LM-1, and LM-2 Products (LM-2 currently requires connecting hardware to allow legacy serial connectivity).
Map Trace and Lambda Trace.
24x24 Ignition and Fuel Maps For Precise Tuning.
Dual Tables For Low/High Boost, Different Fuels, or Alpha-N (ITB) Tuning.
Easy Injector Sizing.
Fuel Trims for Cranking, TPS Tip-In, Post Start, and Individual Cylinders.
Rev Limiter with Fuel Cut, Ignition Cut, or Both.
Rev Limits Per Gear.
Launch Control (2-step) With Anti-Lag.
Full-Throttle Shift.
Use The Check Engine Light As A Shiftlight With Different RPM Settings Per Gear.
Idle Adjustments for Idle Speed, Idle Speed vs ECT, and Idle Ignition Corrections.
Air Temp Corrections.
Water Temp Corrections.
Gear Based Fuel and Ignition Corrections.
Access To Many Other Stock Fuel and Ignition Adjustments.
PWM Boost Control With Simple, Boost By Gear, and Gear vs RPM Modes.
Quad Stage Boost Control.
Adjustable Prime Duration At Key On.
Overheat Protection.
Closed Loop Control With Selectable O2 Input, Conditions, and Wideband Support.
Anti-Theft feature requires inputs or a code to be entered with TPS and Brake pedal. Also has a valet/fallback mode with adjustable rev limit.
2 Multi-purpose Outputs With Fuel and Ignition Adjustments.
1 Multi-purpose Output With Multiple Output Settings Based On MPH.
4 Programmable Analog Inputs For Extra Sensors.
And A Lot More!
pics will be up tomorrow left my charger at work 845 6339498
Demon NepTune RTP and Chipped P28 J-K Tuning
the link above is for *****s that think its a $100.00 ecu
only trades might be one piece suspension!
Seriel Number!
And Usb Cord!
things i need
asr subframe
control arms
si wing
or 00 front end
carbon hood 96-98
carbon trunk ek
Datalog Trimming.
And A Lot More!
