Selling complete swap( as in axles mounts tmount for teg or eg shift linkage ecu harness) outta car 2200$ 3157908321 will seperate block/tranny/headers dont call if you arent serious
BLOCK 99 JDM B18C GSR stock
- arp rod bolts
- type r oil pump
- type r water pump
- Oem Honda Headgasket
- AZ race and machine solid mounts
HEAD GSR P72
- 3-Angle Valve Job
- Supertech Bronze Valve Guides
- Supertech Spings and Retainers
- 2001 JDM Type R Cams
- Hondata IM Gasket
- Skunk2 Pro Series Manifold port matched 68MM
- 68MM Power Throttle Body
- Hondata Throttle Body Spacer
- Golden Eagle Chrome Fuel Rail
- Marshal Fuel Pressure Gauge
- Rs Machines FPR
- AN- Fittings
- NGK Spark Plug Wires
- NGK 7 Plugs
- Bisimoto header ceramic coated
TRANNY JDM B16 HYDRO:
- Stock Internals
- New Syncros Oct 2009
- Honda MTF Fluid
- Stock Pressure Plate
- ACT 6 Puck Sprung Disc
- Comp Clutch 12.5 lbs
- Energy suspension shifter bushings
- arp rod bolts
- type r oil pump
- type r water pump
HEAD GSR P72
- 3-Angle Valve Job
- Hondata IM Gasket
- Rs Machines FPR
- AN- Fittings
- NGK 7 Plugs
- Stock Internals
- Honda MTF Fluid
