(2) obd1 vtec dizzys--2 plug--- 1-125 complete -2missing cap - 100
AEM Tru Time Cam Gears--pollished- $85
b17 cams--50
gsr cams--50
gsr short ram intake--red--40 no filter
d16y8 oil pan tapped for turbo--60
obd2b wire harness--cut up--good for sensors--30
stock b series mounts eg/ek--60 or will sell individually lmk
t brackets--idk what they r think they mayb r mayb singles not sure
2 stock intake manifolds--40 each
timing belt covers--20 top n bottom
stock fuel rails--15
b16 parts--windage tray-20 water pump-15 idk whatelse water neck-40 wit t stat basically a disassemble b16 lmk
stock flywheels--40 each
d15b7 long block--over heated n never restarted after--mayb new headgasket to replace compression n it will start idk--100
h22 fuel line--goes to fuel rail from filter--10
ls head--no cams caps bolts etc.--60
stock obd2a computer--40
stock pressure plates--20 each
dsm 249 injectors--red tops $85obo
parts i need:
obd2a vtec dohc dizzy
obd2a starter dohc vtec
gsr passenger side axle
obd2a o2 sensor
pm or call me 914-469-6034 names rob (rather call cause i rarely check this site)
willing to meet up but not going od distances cause i drive a truck n that isnt cheap on gas so lmk
b17 cams--50
gsr cams--50
parts i need:
obd2a o2 sensor
