Wtf!!!!
  • Wtf!!!!
    So I wake up & warm up my car as usual but when I go to put it in reverse, the clutch feel maaad soft & springy & DOESNT wanna go into gear-_- fuckin great I need a new clutch cylinder either slave or master >:( like I have the money for that...
    UPDATE! WTF ITS NOT DOIN IT ANYMORE!!! SOMEONE PLEASE TELL ME WTF THAT IS!!!!????
    ANOTHER UPDATE!! So I bled it & turns out I just had low fluid with air in the lines -_- I felt weee tooodddd itttt!!! But its shift wayyy better & smoother than before I even bought the car =D
    Anyways all I got left is new tps & new radiator! & this bitch is up f/s or f/t!!! Thro me offers now if wanted
    Sure it's not the clutch master or slave cylinder
      sounds like the slave or master died.
        X2^^^
        Originally posted by LS/Vtec
          Idk I just took a shot in the dark & said clutch...
            X3 I jus had to change my slave cylinder and it was doin the same thing yours is doin..
              u should bleed it to see if u got any pressure
                So I need that
                  I'll try that
                    Try bleeding it, if u get no pressure at all then it's ur master, if not it's ur slave. I dought the clutch will go just like that. The clutch master and slave are both inexpensive so I'd buy both before I go and buy a clutch
                      Thanx bro...I'm on a tight ass budget cuz I have no job & havnt had any luck findin 1 so cheaper the better
                        Defenetly the master or slave.... a clutch don't just give out..
                          sounds like a SLAve ... try bleeding it ... clutch wont just drop out
                            Thanx guys for the help & savin me from wastin money
                              Wtf bump
