WTB: Semi Built Block
  • #16
    • #17
      I bet people will still PM trying to sell me their boys cousins block that runs mint just knocks.
      Sad but true!
      • #18
        B20/vtec b16 head type r valves springs gsr cams arp studs RC 310 s2 I'm bbk 70mm TB catch can setup b16 Tranny exedy street disk light weight flywheel CTR Crank pulley prob missing a few things but she was just freshly rebuilt everything u need to go into an eg chipped p28 needs a tune its in the car now car is garaged motor prob has about 100 miles on it or less no. New oil pump water pump bearings timing belt headgasket rings seals ect. Try it before u buy it
        S3-R
        Stage3-Racing
        • #19
          Only thing it does not include fuel rail or fpr
          S3-R
          Stage3-Racing
          • #20
            Just looking for a block not a swap.
            • #21
              Oh my fault I just read through it real quick
              glwyf
              S3-R
              Stage3-Racing
              • #22
                ttt alex just grab a cheap ls block and some ctr pistons youd spend less buildin it yourself then buying some junk off here and know its 100%
                • #23
                  ehhh shit gets kinda price putting it together yourself especially because you get the itch to go bigger. add up bearing, gaskets, oil pump, water pump, timing belt, rod bolts, head studs head gasket just the little shit gets the price up.
                  • #24
                    That's the only way I would go. Taking a chance with someone else's build/motor will always have me skeptical. Sure you may save some money up front on the purchase but more times than not you'll be putting the money you saved into the said motor to fix mistakes or issues caused by poor assembly. Just my 2 cents
                    • #25
                      I agree^^
                      • #26
                        i agree fully, id buy everything new and have it done right if it was the right set up for example big boost or k series. but if i could get away with a $300-$400 block purchased from some with good rep id do that especially if the only mod is pistons.
                        • #27
                          kyle knows first hand
