lsvtec?
  • lsvtec?
    im going ls vtec im planning on keeping the stock ls crank and connecting rods but im gonna replace the ARP rod bolts and put b16 p30 pistons i dont plan on going to 8,000 rpms maybe like 7,500 its a jdm b16 head what rpm is safe to rev to and if anybody has any info on how to make a reliable lsvtec let me know i could use some pointers havent done this before. i have looked at golden eagle vtec kits and prolly gonna go with them, should, also what ecu should i use along with the swap its gonna be in a 94 civic hatch its a cx, what wiring will need to be done.
    2013 Dodge Dart Turbo.......
    1971 Chevelle malibu
    P28 Ecu....
    WILSON BUILT
      no doubt is my bottom end safe to run lsvtec im just gonna change the pistons and rod bolts
        My Boy Had A Ls/vtec Set Up All Motor It Was Runinn 13s....it Had Some Head Work 2 But U Should B Str8
        WILSON BUILT
          iight thanks for the info.
            you are headed in the right direction. once you do the rod bolts, I don't see any reason that you should not be able to rev the engine reliably to 8200. as far as ls vtec kits go I can help you save some money over the golden eagle kit. also computer wise there isn't a better option than a well tuned computer specific to your engine
            (860) and beyond
            #DavesTuning 8608050968
              for the computer, shouldnt i get a ecu that is the same as the b16 head or get like a gsr ecu because if im right i need hondata s300 to tune and set vtec rpm, i wanna set my vtec at like 5.5 and would it be good to buy a girdle for the bottom end or is that a waste of money.
                hondata isn't your only option. if you want to put a girdle on the mains, it would be recommended to get the engine line honed to take advantage of it
                (860) and beyond
                  so im prolly not gonna go with the girdle because its a lil money to get it honed, but is my bottom end safe with the stock ls crank and rods.
                    I'm running stock LS cranks in 1300 HP motors, you'll be fine lol
                    If you're putting a girdle in and getting it line bored, it would be smart to just put some eagle rods in with a forged piston so you can rev the piss out of it once you get a nice head on there.
                    But even still, I wouldn't bother with the girdle. And also, since you're changing so much stuff out why not find a GSR block? I've never understood why NA guys do an LS-V, sure you make a few more ft-lbs but always seems more trouble than it's worth lol
                    9.85 @ 145 Single Cam
                    Hot-Rod coming soon
                      you'll be straight to go high rpm's if you have arp rod bolts. As for ecu's. Hit up Dave or Hermin and get a chipped ecu wit a basemap for your setup. And then have Dave tune it. Dave or Hermin or who ever basemaps/tunes it can put your vtec/rev where ever you want. 5,500 is kinda high for vtec. If your trying to tune it to that it'd be cheaper to just get a jdm p30 ecu. As for pistons and rods hit me up PM i have high comp pistons for a LS already on LS rods.
