Details
98 Integra
GSR Swap
Bone Stock everything with a Skunk2 intake mani
Obd2 to Obd1 Jumper
CKF Bypass
My car is killing gas.
My air/fuel is all over the place.
Ever since last week I un did my battery for a min well working on the car. When I hooked up the car it ran rich as shit. Killed gas like crazy. I thought maybe fucked up the chip inside the ecu. So I swapped tunes. Nothing. I swapped O2' sensor. Now the car runs lean. And my gauge will go all the way Lean and the car will cut out. If I hit the gas hard it will go back to rich and run normal. If I unplug the O2 sensor the car runs good. Idk whats wrong with it.
The reason I don't think the sensor/gauge is bad, is because when it goes down to lean while driving my car cuts out. So it must be reading accurate. But thats crazy at idle. It's almost as if it's a narrow band with a autometer gauge like a fucking light show.
I swapped...
-Injectors
-Fuel Pressure Regulator
-Intake Air Temp Sensor
-Dizzy
-Engine Harness
-P72 Ecu Virgin
-P75 Ecu Virgin
-Map Sensor
-TPS
-Throttle Body
-3 differ O2 sensors
All the parts I swapped. I swapped with parts I knew worked.
Checked for vaccum leaks. Nothing.
My vaccum reads good.
Nothing same shit.
98 Integra
GSR Swap
Obd2 to Obd1 Jumper
CKF Bypass
I swapped...
-Injectors
-Dizzy
-Engine Harness
-P72 Ecu Virgin
-P75 Ecu Virgin
-Map Sensor
-TPS
-Throttle Body
Nothing same shit.
