Lsv questions
  • Lsv questions
    Gsr head ls block
    Do I use the gsr timing belt
    Can I use gsr head studs or ls
    And any other info will be good
      gsr timing belt... gsr water pump... gsr headstuds... dat is all u have to change...
        bump for leo
        tengo caimanes k s comen t rottweiler huelebicho
          you dont have to change all that but it would be best if you did and the gsr headstuds would recomend ARP. Keep in mind block is stock, so try not to rev high and if you want to rev hight get some ARP piston rod bolts.
          becuase its JDM!! It has to be better!
            i hope it blows up. but.
            like the guy above me said.
            You run the same timing belt as your waterpump. So if you're running a stock ls block with ls water pump (19tooth) then run LS timing belt. If you step your game up to a gsr/itr water pump (22 tooth) then run gsr belt.
            As for head studs LS ones wont work. I'd go with arp if it's an option. If not then get gsr.
            And do it the right way and use fuckin dowel pins.
              I have the same sit up Gsr head ls bock .. It's a good match
              -->BPT<--
              aLL M0toR Ls vTec
                Bump For Another JUNK ASS LEO BUILD That Will End Up Blown Or For Sale. Smh Just Get Out The Honda Game...
                S14 Zenki.
                Mayhem Autoworks.
                Hubbard Park Pizza.
                EST Motorsports.
                MBFilms.
                United States Marine.
                  wow lol
                    Yo all you gonna need is arp head studs bro everything is on that shit remember it was from a lsv setup so the arps is all you gonna need...
                      Boost FTMW!
                      Hidin' out
