I put a 97 b20b in my hatch. Changed the long intake to a ls short intake and am using the b20 throttle body. Put a ls obd1 dizzy and everything plugged right in. Firing order is good. Check engine light is on but I haven't connected my o2 sensor yet cause I have to extend the wire. It runs rough and when I rev the motor it stalls and turns off. I'm stuck
Need help on my b20 swap in a eg hatch
Originally posted by CTgoldhatch View Postif you are runnin a obd1 dizzy shouldent matter that is all built in the dizzy. make sure the timeing marks are right and do a compression test.
Originally posted by elpepe View Postwhen you say rough what exactly do you mean?? misfire, holds back power?? can be alot of things more info/details will narrow down suggestions
