hey I put a d15b8 block with a d16y7 head and intake into my 98 dx. everything runs and runs good but im dumping white smoke...coolant obviously burning up. I did the head gasket myself and have great compression so I know its not a blown head gasket or cracked cylinder. I have checked all the hoses to verify them in the right places and I don't see how I could have screwed it up....everything pretty much points to where it goes with the preformed hoses. just hoping someone else has run into this and has an answer or could point me in the right direction!.....203-910-5364 greg thanks in advance for replies
rebuild problem! please help
White smoke means coolant is going into your combustion chamber. Theres only 2 ways coolant can enter your combustion chamber and its either through the head gasket or a cylinder wall. You could have a warped head or your head might not have been torqued down correctly. Your hoses will have nothing to do with smoke coming out the tail pipe. Did you re-use your old head bolts? Did you use a new head gasket? Did you do a compression test to actually verify that you have good compression in all cylinders?
I used new head gasket, head bolts, and tightened down in proper sequence and in the 4 step torque procedure.....my compression test showed #1-110 #2-115 #3-110 #4-110 so I'm stuck next step is taking manifold off and replacing throttle body gasket and intake gasket and getting head decked....I checked it with feeler gauges and it did t show warp but maybe I missed it...idk thanks for reply man any other input is greatly appreciated too.
I did run straight edge and used feeler gauges it seemed Ok to me cause I couldn't get a .002 feeler to go under straight edge...idk maybe I just missed where its warped....thanks for all the help I'm pulling off the head again and will try again....anybody suggest any place to shave the head in Wallingford area?
Don't shave it just buy mine lol... If u shave it and it happens again u not gonna b able to shave no more and u gonna have to buy a new one newaysLast edited by jdm94hatch; 10-20-2013, 11:20 PM.
did you identify which cyl is burning? if its dumping water in the cylinder the plug will look clean from the steam cleaning in the cyl. if you are confident the that block and head as true i guess its possible that the cooling jacket that goes from the head to intake could be leaking coolant into the num 4 cyl. never seen it happen but in theory it cold happen
Your car's main problem is dumping white smoke and burning up coolant. sometime it happens but don't worry about it. I know who will fix it easily, I have been regular customer of Import Auto Repair Services and it provides expert services that will makes your car running smooth as ever. It has done a good work on my auto repair needs. It offers wide range of auto repair services including engine service, oil changes, breaks, shocks, alignment, suspension, ac service and other repair services that your car may need so, I recommends you to must visit Import Auto Repair Services.
Originally posted by Ruger37 View PostI used new head gasket, head bolts, and tightened down in proper sequence and in the 4 step torque procedure.....my compression test showed #1-110 #2-115 #3-110 #4-110 so I'm stuck next step is taking manifold off and replacing throttle body gasket and intake gasket and getting head decked....I checked it with feeler gauges and it did t show warp but maybe I missed it...idk thanks for reply man any other input is greatly appreciated too.CT-OUTLAWS
