does honda use motor oild for Tranny
  • #16
    Originally posted by NHSwaps13203 View Post
    ill be sure not to take my car to any of you for a tranny fluid change.
    you need two. and dont listen to anyone on here. THEY ARE NOT THE SAME. to get you by for a weekend untill the dealer opens is fine. Not permanatly. Even honda says if you have clunky, hard to shift gears or grinds then you need to drain the oil and refill with there new mtf. jea
    Exactly. I always here people rant & rave about GM syncromesh, the only reason it doesn't cause your tranny to grind when it normally would, is beacuse GM syncromesh is real thick, which slows the revolutions of the tranny's internals, so obviously it doesnt lube all that well.
    Honda Fluid is for lubrication, not to slow gears down for proper gear engagment, that's what syncro's are for.
    Properly built tranny's dont grind, no matter what fuild is in it. Ask me or Nick about that.
    But to answer the first question: Yes, Honda's OLD tranny fluid(Red Cap) was conventinal 5w-30 oil, & There NEW Fluid(White Cap) is Synthetic 5w-30 with a couple extra additives.
    Honda NEW (White Cap/Green Label) MTF FTW
    • #17
      what he said.
      • #18
        you can use 10w30. prefably i'd go with oem honda or eneos.
        • #19
          i was thinkin bout puttin sum of that lucas oil stabalizer in mine think it'd b good or bad
          • #20
            sh*t i jus put grease on mine
            • #21
              no disrespect but yo just stop bein cheap and go to the honda dealer and buy some tranny fluid, its like $10 a bottle and you have to worry about no bull$hit
              • #22
                $10 a bottle??? god damn man what honda dealer you be goin to thats expenxive as ************, im pretty sure that shit like half that price maybe less
                but ya that oem fluid always worked good for me in my tranny no problems g/l man
                Build In The Making!!!! BackYard Built Not Bought!!!!
                • #23
                  ctvtec pro damn look at u go haha its been a min hit me up!! i for sum reason dont got ur num no more!
                  • #24
                    oem honda all day
                    • #25
                      no...worst shit ever
                      • #26
                        Bg syncro shift
                        WILSON BUILT
                        • #27
                          thanks 4 da help
                          • #28
                            i said like $10 which means about, i aint give an exact
                            • #29
                              get oem mtf fluid
                              Nulla Tenaci Invia Est Via – For the tenacious, no road is impassable. - Spyker
                              • #30
                                well said,
                                GM syncromesh is the truth for old worn tranny's......but do not use it in a fresh tranny the (friction modified fluid) actually creates additonal friction which helps worn syncro's to engage. but for a tranny with fresh syncro's you don't want to create friction.... u want to reduce it
                                In short
                                Fresh Tranny - Honda MTF
                                Tired Tranny - GM sycromesh (friction modified)
                                PS I The OLD Honda MTF was actually the same as their motor oil :(.......they changed that about 2 years ago
                                Originally posted by NHswaps13203
                                Doc brown called me to get the delorean wired, i was busy wiring the batmobile.
