ok so im having problems with my transmission on my 08 SI first reverse grinds and its really hard to get into gear or get out of gear it does not matter the engine speed its still hard i have to put a lot of force into it and second gear grinds at high rpm s. has anyone had this problem ??
08 SI Transmission Problems
I say check the clutch fluid. Otherwise I think it's the clutch.
But it could also be master cylinder failing.
And like they said. Check the transmission fluid.
But the way you explain the behaviour sounds like clutch. But once again it could be any other thing too.
I don't think the transmission is the problem. It's a 2008 transmission and if it was only the transmission it wouldn't be doing that in ALL gears. I give 80% the clutch is the problem.
Good luck!
Apply it!
Did mike call me on this this morning?My transmission's went 9's
http://youtu.be/z2PHemIp_Tg
Originally posted by XxJimmy91xX View Postthnks guys i adjusted the clutch pedal and no grinds on any gear an it shifts like butter now thanks everyone
I will see if I can adjust the clutch pedal in my transmission too.
I'm having kind of the same problem too.
Apply it!
