Engine idleing when stop or in nuetral,
  • Engine idleing when stop or in nuetral,
    Engine idles hard when stopped, anyone kno wut it could be?
    Does it wanna shut off? Idles around 300-500 rpms? More details
    Originally posted by nano0222
      probably bad grounds by the engine, thats how my car was , use to idle low , seem like it was gonna shut off then it go up on rpm to like 700 , and only does it on idle . so check your grounds under the hood & if not could be a sensor going bad .
      98Ex DD EJ8 ROADRUNNER
        vacuumm leak is a good probable cause
        MSU
          Ok so it started idling wen my engine started to overheat, I bought a new thermostat and gasket so wen I change that would I have to change the sensor too
            yupp gotta change the sensor too ....
